Multifunction DAQ
measurement and automation usb recognize
Earlier, I had turned off MS Security Essentials and Comodo Firewall, without success.  After your suggestion, I un-installed both of them and turned off the Windows firewall too.  I then re-installed each of them one at a time and tested to see if the DAQ could be detected.  So far the DAQ is being detected reliably even with these programs installed now.  I wonder if there was a setting in Comodo that was preventing the DAQ detection (and simulated DAQ installation) even when the firewall and malware detection were turned off.
I'll keep checking it over the next couple of days and let you know if it's working.
Thanks for all your help with this.
Message 31 of 33
(1,004 Views)
This seems to have done the trick.  The DAQ is now being recognized reliably.  Thanks again for your help!
Message 32 of 33
(984 Views)
I'm glad to hear we were able to sort out the issue.  Thanks for your patience and good luck!
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 33 of 33
(982 Views)
