need usb 6008 driver!
Hello! I am trying to use a usb 6008 with MAX and I can't find the driver for the 6008 anywhere! I'm not sure if I have the right disc, but when it asks for the driver disc after I plug in the usb I put in the NI-DAQmx 8.8 disc that came with the usb hardware and the driver cannot be found. I've tried having it search online for a solution but that doesn't work either. Does anyone know where I can get the driver for the 6008?
Message 1 of 8
(4,282 Views)
8.8 is old. When did you order the device? What OS are you using? Download the latest.
Message 2 of 8
(4,281 Views)
The device was ordered in June 2010 (according to the box). I'm on Windows Vista Ultimate. Currently downloading NIDAQ940f5 as suggested.
Message 3 of 8
(4,278 Views)
I have the USB 6008 as well, as far as I know it needed no driver, but i also had problems with labview 8.5, when i switched to labview 2011 it worked 100%
Message 4 of 8
(4,262 Views)
I'm currently using LabVIEW 2011 and all I get is a request for the driver disc. The disc I have doesn't seem to work, so I'm not sure what to try next.
Message 5 of 8
(4,235 Views)
Did you download the driver and run it?
Message 6 of 8
(4,232 Views)
Have you got DAQmx as well as Labview 2011? Cos afaik that came with all the drivers you would need.
Message 7 of 8
(4,217 Views)
Ok I downloaded the most recent version of DAQmx like you said and that contained the right driver. Thank you very much!
Message 8 of 8
(4,198 Views)
