Multifunction DAQ
reading two AI's with ni-usb 6009 and make a pump curve
Hello all,
I want to read the signal of a pressure sensor (0-10V) and also the signal of a flow sensor (0-10V) to make a pump curve   p=f(Q)
Can someone help me with this please??, I'm just a beginner in labview and do have a 30 day trial version of labview 8.5
Thank you for your assistance
Torsten
(2,873 Views)
Hi Torstern,
You could start off with using DAQ Assistant to build your first acquisition VI
Once you get going, I would suggest you to start using the DAQmx acquisition VI's given in Examples shipped with LabVIEW
LabVIEW>>Find Examples>>Hardware Input Output>>DAQmx>>Analog Measurements>>Voltage Folder will have the required examples.
You could read each VI's Documentation to understand how it works and how to connect signals
(2,848 Views)
