10-04-2006 09:24 AM
10-04-2006
11:12 PM
- last edited on
07-15-2025
04:19 PM
by
Content Cleaner
Here is some info for you regarding NI DAQ driver support
You will find that PCI/PXI 6143 are not supported by traditional DAQ ( only supported by DAQmx)
Where as PXI 6733 and 6704 are supported by traditional DAQ( also supported by DAQmx). Install the version of Device Driver found here
One advise: If possible try to upgrade your VI's to DAQmx, Because of the advantages it has over the Traditional DAQ
Hope this helps
Regards
Dev
10-05-2006 09:48 AM
the problem i'm find when using the DAQmx, is that it is taking up 2MB of memory to run it. I am trying to reduce this as much as possible and figured using old vi's would help.
10-05-2006 03:39 PM
