ssh access to NI9181 from Linux host
Dear,
I cannot find any good idea to access and receive data from NI9181 through SSH.
Since host should run Linux, many difficult issues there are.
No device drivers, and no examples.
Most of recommendations are using VM, but it is NOT proper in my case.
(https://forums.ni.com/t5/Multifunction-DAQ/AI-with-cDAQ-9181-on-linux/m-p/3358897)
Any idea to resolve this?
thanks,
(2,417 Views)
Accepted by johndo777
cDAQ-9181 is designed to be used in windows environment.
It is not possible to access data through SSH, cause it is protected.
You can think about other options, DAQ device with controller which has its own operating system such as Real-Time OS. ex) cDAQ-9132
Then you can get data with communication between PC and cDAQ.
(2,375 Views)
Thanks Chan82,
(2,369 Views)
