the probelm appears after changing my computer's hardware
i use pci-6033E daq card. it works very well in my old computer. however,after i put it into a new computer,the vi which i used on my old computer do not work anymore. when i execute the vi program,labview will search subvi and show "PolyVi'Ai Acquire Waveforms.vi' is missing".
(2,479 Views)
When you installed that card in your new computer did you install NI-DAQ? If so, did you install LabVIEW support for NI-DAQ? It sounds like the LabVIEW support may not be installed. The best way to find out is in LabVIEW to check and see if you have the data acquisition palette. It sounds like it might be missing. If that is the case, modify your installation of NI-DAQ to include support for LabVIEW.
Steven B.
(2,479 Views)
Of course,I have installed ni-daq driver(7.0) and labvew(6.i). In fact,the vi program which I used works very well on another computer. but after i just copyed the vi program to new computer,the diagram of "AI Acquire Waveforms" became "?".
(2,479 Views)
