usb 6211 hook up help
I am using every channel of the daq board.  I would like some advice as to how i should mount this while keeping it looking clean.  I have eight inputs coming in from "the outside world" all the rest are on a circuit boad (smaller than the daq board).  I guess i was just wondering if there are any enclosures that i could buy that would help this look profesional to the customer. How do i hide the hook-ups to the daq board?
Mark Mutton
Electrical Engineer
(3,576 Views)
There are probably thousand of enclosures on the market you can use. One possible solution is to use a CA-1000 enclosure from NI. You should be able to insert the 6211 into the CA-1000. I've never done this, so please check the size of the 6211 and CA-1000 before you buy it!  Smiley Happy
Hope that helps.
Luca
(3,566 Views)
Hello
You may want to consider the USB-6000 Series Prototyping Accessory:
https://www.ni.com/en/search.html?q=779511-01&ps=10&pg=1
It is basically a plastic enclosure that holds a 16-position combicon connector.  The picture you see shows the top piece off so you can see inside.  The accessory kit also includes the little prototyping board you see pictured in case you want to add any circuitry to it.
On the left side there is strain relief for all of your cables coming out of the device.
Let me know if you have any questions about it.
Brian
(3,542 Views)
