what device to connect SH 1006868
Hi, we bougth 3 PCI cards from National Instrument.
We use PCI 6031 E and we bougth a cable called SH1006868...This cable connects to 100 pin E series devices and ends with 2 female 68 pin 0.050 series type D connector. Then we would like to connect these cable to my device but I don't know where I can find a male 68 pin 0.050 series D type connector. Following that, my idea is then to find a connector which can be assembly to SH1006868.
ps: I am french then sorry for my english...it is emergency then thank you for your help!!
(2,737 Views)
Typically, the solution is to use one of our terminal blocks which do have the male 68-pin connector you are referring to. There are several options including the SCB-68 Shielded Terminal Block and the CB-68LP low cost terminal accessory.
If your application requires interfacing to a custom system, you may need just the male 68-pin board mount connector. If this is the case, we have a very good Knowledge Base article that lists part numbers and manufacturers for most of our connectors. See Specifications and Manufacturers
for Board Mating Connectors
I hope this helps!
Russell
http://www.ni.com/support
(2,737 Views)
