Multisim and Ultiboard
10.0.1 Patch file will not finish downloading, stops at last two minutes (failed to connect to server)
I re-installed NI Circuit Design Suite and then attempted to install Patch 10.0.1 numerous times.  During the last two minutes of the download, it continually states that it lost server connection and is unable to connect.  I have tried to reconnect numerous times without any success.
(3,324 Views)
Hi Radams:
I don't know why you are getting lost connection errors, but there are other ways of getting the update.
https://download.ni.com/support/circuitdesignsuite/10.0.0.1/NI_Circuit_Design_Suite_Update_10_0_267....
Just select the installer that applies for you.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,318 Views)
