Multisim and Ultiboard
655X Labview Instrument for Multisim issue - Multisim 14.1 version
Hello everyone!
How can this problem be solved?
I followed the instructions "Digital Waveform Generator: Using the NI6551 Instrument in NI Multisim" at the link:
https://forums.ni.com/t5/Example-Code/Archived-Digital-Waveform-Generator-Using-the-NI6551-Instrumen...
but when I open the virtual instrument the following error message appears:
Unable to show the LabVIEW instrument. The LabVIEW instrument library "LVInstrIF1600/655X_Digital_Wfm_Generator" cannot be found or loaded.
Ensure the VI library file exists in the LabVIEW instruments path "C:\Program Files (x86)\National Instruments\Circuit Design Suite 14.1\LVInstruments\".
Thanks in advance for your answers.
(2,664 Views)
I'm having the same issue. This tutorial is archived, so maybe MultiSim 14.1 doesn't support this instrument? If not, is there another waveform generator that can be used to generate a pulse?
Mike
(2,614 Views)
