Multisim and Ultiboard
A problem of "Postprocessor" option
I want to use the postprocessor to manipulate the output from analyses . When I open the "Simulate" option , I cannot find the "postprocessor" option , as shown in the following figure. I don't know why.Thanks in advance.
(3,402 Views)
Accepted by mnily
It is probably because the post processor is not in your version. From your menu, I think you have version 8 or version 9.
If you have version 8, the post processor was not in Multisim Pro (it is in Power Pro) and Student Lite.
If you have version 9, the post processor was not in Student Lite.
If that isn't the case, let me know, and I can give you some other possibilities.
If anyone is interested, I could figure out the version because the Probe (Probe Properties...) was new in version 8, and the lightning bolt icon last appeared in version 9.
Message Edited by GarretF on 01-20-2010 08:00 AM
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,388 Views)
