Multisim and Ultiboard
Autorouter Options?
Hi all,  me and my coworker are wondering if there is anyway we can make Ultiboards AutoRouter to make some of our wires the same length or we can
somehow configure the length of the wires so it would be easier to replicate them to each pin (Is just that the wires are into a clock in which they have to be the same
exact length) , let me know what you guys think. Thanks for any help.
(4,308 Views)
In order to answer this question I need to know your Version of Ultiboard (i.e Full, Power Pro, Education). You can find that under HELP>ABOUT ULTIBOARD.
Message Edited by lacy on 10-03-2007 06:55 PM
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,303 Views)
My current version is the educational one, but my supervisro got us a profesional one , but its just one so we have to instal it in the lab and share it. But if this this one has something useful about this issue we can just use it for that, thanks Let me know
(4,298 Views)
O.K. I will give you the universal version of my idea for you to try that way it should work with all versions. Goto TOOLS>NETLIST EDITOR.  Select your net you want to work with in the top drop down box Find the area that say TOPOLOGY and select anything other than SHORTEST. Then you will find in the middle of the box a bunch of tabs. Click on the one that says HIGH SPEED. Goto the very bottom of this box and check ROUTE LENGTH CHECK. You will find there 2 boxxes for maximum length and minimum length. You can choose your lengths there. In my opinion, you would want max and min to be set to the same that way you are assured that it won't exceed this length and also won't be shortened during routing.
I tried this on a test board. You may have to experiment with your parts placement in order to assure that it can achieve the maximum length. This was one thing I ran into when testing this procedure. You can try this and see if it will work for you. There may be other options that may be better than this, but this is all I know right now.
I hope this is what you need.
Have A Nice Day.
Have a Nice Day
(4,296 Views)
Oops, I forgot to mention that you need to do this for each net that you wish to change. This way you can set only the nets you want to the same length while leaving any others alone.
Have a Nice Day
(4,293 Views)
