Multisim and Ultiboard
Can't figure out how to see a reasonable graph of a simple circuit
 When I run this and use the interactive grapher, all I see are lines blowing by at lightspeed.  My expectation was a that I'd see a gentle sine wave, ideally in real time.  How do I tame the grapher?
(2,033 Views)
Привет! Нужно изменить параметры развёртки осциллографа (покажу в своей версии MS)
(2,003 Views)
Thanks.  I don't read Russian well, but I was able to follow along.  I am using a very different version of Multisim, I think. My Grapher setup looks nothing like that.
My trace is scrolling (?) so quickly it isn't usable.
(1,963 Views)
-а я Вам и хотел указать, что дело всё в настройках пробника, или как там его обзывают в Вашей версии...
Должны быть какие-то всплывающие окна с настройками, или дополнительные свойства, где все параметры настраиваются. А Ваш прибор работает с теми, которые установились по умолчанию. Поставь те себе хороший браузер, который переводит всё автоматически с большой точностью.
-например.
Удачи!
(1,952 Views)
Accepted by TonYenn
Hi TonYenn and tipa,
To be able to see a pleasingly moving waveform you need to choose a frequency which is not a harmonic of the Grapher's retrace frequency (oscilloscope's retrace frequency). If a repetitive waveform's frequency is less than the retrace frequency you will see strange trace(s) such as "lines blowing by at lightspeed". If a repetitive waveform's frequency is a harmonic of the retrace frequency the waveform will appear stationary.
I created an example which you can easily reconstruct, please refer to the attached screenshot below for the values of the components.
The default setting of the Grapher is 1 ms/div, there are 10 divisions. The total time of 1 complete trace is thus 10 ms, so the retrace frequency is 100 Hz.
I set V1 to 100 Hz so this will appear stationary. I set V2 to 150 Hz so this will appear to move.
I use the Split mode so that I need to post only a single screenshot. The Split "button" is encircled red in the screenshot.
On the Grapher window, change the trigger type from None to Normal. The drop-down list is encircled yellow in the screenshot.
However, no tool for capturing video frames is available in the computer that I'm using so I can only post still image/screenshot. You can simply reconstruct the circuit and do the simulation to see how the Grapher displays the waveforms.
G. Goodwin
(1,932 Views)
