08-24-2011 03:16 PM
After downloading and unpacking the multisim installer, i get this error during installation:
Error 1334. The file 'lvinstrif1000.llb.EWB.CORE.110' cannot be installed because the file cannot be found in cabinet file 'Data1.cab'. This could indicate a network error, an error reading from the CD-ROM, or a problem with this package.
08-30-2011 09:06 AM
Hi Rakosmanjr,
This is a generic error from the MSI installer indicating a missing or corrupt file, please download the installer from our website and try again.
On our website, there are patches only installer which means you must have Circuit Design Suite already installed and if you install the patch only, you will likely get similar error.
The 30-day evaluation self extracting zip file, once you finished downloading the file, double click on it to extract the installer to:
C:\National Instrument Downloads\Circuit Design Suite\11.0
Once all the files have been extracted, you should get an option to start installing. The Circuit Design Suite\11.0 folder should be approximately 474 MB for the Pro and about 452 MB for the Education, check the folder size and size to make sure you downloaded the right file.
08-30-2011 01:32 PM
Re-downloading it did not help. ![]()
