02-10-2011 08:46 PM
Anybody used MS to simulate crosstalk in PCB traces?
I have a design with 72 parallel comparator outputs that go to a CPLD. max length is 10 inches. Not a lot of width through the area to route.
I tried several online crosstalk simulators and got wildly varying results from -3.2 to -25 dB for the same PCB structure. I could live with -25dB, but definetly not -3.2dB.
I'm looking at an 8 mil trace with 8 mil spacing and a ground plane at either 11.9 or 6.4 mils spacing. Er is 4.5. Source drive voltage is 3.3V and risetime is 20nsec. No additional source or load terminations
(Low Z source and High Z load)
Any recommendations?
Thanks.
11-22-2012 01:31 PM
I haven't been able to find any examples or other work people have done on crosstalk. Interference dependent on component placement (as well as far and near crosstalk) isn't a feature in Multisim nor Ultiboard. Though if you have the knowhow in SPICE, you should be able to add parameters to custom amde components to create a scenario, ofcourse that would imply that you'd need to know the kind of crosstalk you're talking about as well as SPICe coding experience.
Best Regards,
