Multisim and Ultiboard
DRC doesn't find any errors
Im using Ultiboard 12 to route my board. First, we used a space between the path of 0.13mm. Now as we tried to set the whole project to 0.15mm we have the problem that we can't "convert" the project to 0.15mm since we can't find all the spaces which are to small.
Even when I enter 2mm as space between the path, the DRC doesn't say anything. Even when I start the DRC check, it says everything is fine. Is there anything I do wrong?
Regards
Patrick
(4,152 Views)
Hi Patrick,
Have you defined the PCB rules and constraints correctly?
Perhaps some constraints are not set and that's why the DRC check doesn't complain?
Best regards, Hendrik
(4,141 Views)
