Multisim and Ultiboard
Database access denied for 2N3055A
I'm using the Student version 11, on my Win 7 (32 bit) laptop. The online PDF document seems to show that the 2N3055A transistor should be available for through the student version, but the software still won't let me use it. What am I doing wrong here?
Message 1 of 11
(5,513 Views)
In Multisim go to Help>>About Multisim, what's the application version (11.x.xxx)? Database version? Do you have an Administrator account on your computer?
In the meantime here is the 2N3055A, open the file, right-click the component and select Save Component to DB, this will save the component in your User Database.
Fernando D.
Message 2 of 11
(5,480 Views)
Thak you. It worked.
Ahmad
UOIT, Oshawa, ON
Message 3 of 11
(5,333 Views)
Hi Ahmad,
I am glad to hear that this solution worked for you.
Have a nice day,
Fernando D.
Message 4 of 11
(5,325 Views)
Hi
Where I can find the file for MJE172 (PNP transistor) and MJE182 (NPN transistor)  for multisim?
I am working on a project that needs the above transistors.
Thank you
Message 5 of 11
(5,298 Views)
You can find the SPICE models for these components in the On Semiconductor website. Try these links:
MJE172
MJE182
Here is a tutorial on how to create basic components in Multisim:
Component Creation 101
Fernando D.
Message 6 of 11
(5,294 Views)
Thank you for the files.
How can I use them? I clicked them and they are text.
It seems I have import or paste them somewhere. Or I should save them in a certain folder?
Thank you
Message 7 of 11
(5,290 Views)
The files that I sent you are the SPICE models, a mathematical representation of the component. Now you have to create the component in Multisim usign the Component Wizard (Tools menu). Take a look of the tutorial that I sent you (Component Creation 101).
Fernando D.
Message 8 of 11
(5,284 Views)
Thank you Fernando
I just add the both transistors into my system.
If you look however one looks blue and other black. For one I entered the the pin layout as to TO-126 and for the other I didn't. Is that the reason?
MJ172 and MJ182
Message 9 of 11
(5,279 Views)
Black components are virtual, they can be used for simulation only.
Blue components are real, they have a footprint (for instance: TO-126) and they can be used for simulation. Real components can be transferred to Ultiboard for the PCB layout.
Fernando D.
Message 10 of 11
(5,271 Views)
