Multisim and Ultiboard
Dependent sources circuit: need help
Hey,
I have a circuit analysis assignment due, I've done the work by hand but I want to use multisim to check my solutions. Can someone give me some hints as to how to put in the dependent sources shown in the attached circuit.
Message 1 of 9
(15,189 Views)
pat666,
I believe you need to have either a ABM Voltage Source (Analog Behavioral Model) or you could use a Current Controlled Voltage Source and Voltage Controlled Voltage Source respectively.    In the database go to the Sources group -> CONTROLLED_VOLTAGE_SOURCES and this should allow you to do what is described in the schematic at those designated nodes.
Pat Noonan
Message 2 of 9
(15,163 Views)
Hi, _user32
seems that ABM_voltage source does not accept the expression with current, only voltage variable, is it?
Best,
Message 3 of 9
(14,192 Views)
There is a component called ABM_CURRENT under the CONTROLLED_CURRENT_SOURCES Family. You can use this for current.
Hope this helps.
Tayyab R,
National Instruments.
Message 4 of 9
(14,176 Views)
Dear Tayyab R
I need a voltage Source having V-I relation as:
V=-0.0202*I+0.1502*I^3, where I is the current through the source itself.
Below is what I modeled in Simetrix, could I implement this in multisim as well?
Message 5 of 9
(14,164 Views)
Tang_Lihua,
I do not have Multisim but in Spice 3 that can be modeled with a linear independent voltage source (V1) set to 0 and a non-linear dependent source B.
V1 is used to measure the current.  A transient analysis with the UIC option shows a sine wave at about 7 kHz in the circuit listed below. To do an AC analysis, a non-zero value of AC must be entered for V1 or some other source.
Test Arb source
V1 1 2 DC 0 AC 0
B 0 1 V=-0.0202*I(V1)+0.1502*I(V1)^3
Rx 2 0 1G
L1 2 3 20m
C1 3 4 20m IC=100u
R1 4 5 10m
C2 5 0 25n
R2 5 0 1G
.END
In the lower image the x-ais should be Frequency, not Time.
Lynn
Message 6 of 9
(14,150 Views)
Dear Lynn
thanks for your reply.
Does spice 3 have any user interface? I need to add more advanced components.
Message 7 of 9
(14,145 Views)
Tang_Lihua,
I suspected that the envelope should not be constant but did not take the time to pursue the reason.
The version of Spice that I use is a port of the Berkeley code to the Macintosh called MacSpice. It uses a command line interface.  It does not have any schematic capture or even a text editor.  It can plot results, but I export the data and plot it in a LabVIEW program I am developing so that I have more control over the plotting.
Lynn
Message 8 of 9
(14,139 Views)
Dear lynn
thanks anyway.
Message 9 of 9
(14,127 Views)
