Multisim and Ultiboard
How to import Spice model net list to Multisim
Dear forum,
I am Using Multisim and Ultiboard software for circuit simulation and PCB Development.
I am facing issue while creating custom component in multisim.
i will be attaching the all the screen shots for better understanding of my problems in multisim.
Opened new design FileOpened new design FileCreating the custom component (Tool-custom component wizard)Creating the custom component (Tool-custom component wizard)Filling up Custom component name and author  filed.Filling up Custom component name and author filed.Selecting the Footprint type and Number of pin count.Selecting the Footprint type and Number of pin count.Creating a symbol for LM1117Creating a symbol for LM1117Assigning the pin direction. What is section column means there?Assigning the pin direction. What is section column means there?Mapping of pins with footprintMapping of pins with footprintafter  mapping of all the pinsafter mapping of all the pinsModel name and Spice model file.Model name and Spice model file.Pin mapping tablePin mapping tableAdding component to analog familyAdding component to analog family
Circuit is created based on the typical application informationCircuit is created based on the typical application information
Simulation is running, Red line is input and Blue line is Output.No output at channel B.Simulation is running, Red line is input and Blue line is Output.No output at channel B.
https://www.ti.com/lit/ds/symlink/lm1117.pdf
https://www.ti.com/product/LM1117/toolssoftware
Using this spice modelUsing this spice model
For customizing the design which spice model need to be used and how to do pin mapping for custom created symbol.
There is one video for to showcase this how to create custom model and importing spice model to that, but that video is not much help full to know the things. is there any better video to know how to import custom spice model to multisim. kindly help me to get solution for this problem.
First zip file is original zip file. Second zip file is edited one, in second zip file .cir file was not there so i copied the net list of LM1117 IC. made .Cir file myself.
(3,445 Views)
Hello NaveenGBhat,
Have you had a chance to review this documents?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH5fCAG&l=en-US
http://zone.ni.com/reference/en-XX/help/375482B-01/multisim/mappingpins/
http://zone.ni.com/reference/en-XX/help/375482B-01/multisim/advancedpinmapping/
__________________________________________
The best way to thank, is to give KUDOS
(3,184 Views)
