Multisim and Ultiboard
How to simulate APEX SA03?
Hello my friends,
          I want to test APEX SA03 (The SA03 is a pulse width amplifier that can supply 3000W
to the load.) in Multisim power pro.
          However, there is no relevant spice model in Multisim power pro, so I download a spice model in web. but it's format is *.LIB.   I may open it by notepad.
IF I swap it's suffix  for *.cir, would our multisim go wrong?
There is a test circuit for SA03 in sa03.zip
There is SA03.LIB in sa03.zip
                          Thank you for your help!
(4,577 Views)
From the ".lib" file you can open it in notepad, and the model you need is between the .SUBCKT line and the .ENDS line, everything with a * preceding the line means a comment, so you can either ignore or include... I would recommend to include but sometimes they give trouble...
To create the component please follow our Tutorial: Creating a Custom Component with in NI Multisim, if you have any questions after going through the tutorial you can post them here, or contact support at ni.com/ask.
Nestor
(4,565 Views)
Nestor,Thank you!
         I have already done according to Tutorial which you offer, but my circuit's results (output) go wrong ultimately, I don't know what  is  wrong?
Help me check up my circuit,please!
        谢谢您!(Chinese)= Thanks you!
帖子被Fangel在03-17-2008 09:00 PM时编辑过了
(4,555 Views)
My friends,
         Please help me to check up my circuit and the spice model of SAA components. Tell me why are its results wrong?
This is a simple application ,but unfortunately I can't do right.
(4,530 Views)
Fangel, the component is correctly created. I looked at this circuit and I made changes:
1. R1 has to be 10k according to the datasheet you attached.
2. Input -PWM must be "floating", not grounded. So I deleted the GND terminal and net... and then created a new net coming out of -PWM and just ending in mid-air.
3. Ground channel B of the scope.
4. Deleted the scope attached to the CLK inputs. (instruments introduce components into the circuit)
I run the circuit and it shows a beautiful PWM coming out...
Nestor
(4,363 Views)
