Multisim and Ultiboard
How to update incorrect models in component database?
How can I update incorrect models in the component database like the 74HC163? Where can I find the correctly updated models?
I'd also like to remember to my previsious post (09-13-2008) regarding the "Not enough nodes Found"-Error when using  the  SPN1N60C3 MOSFET from Infineon, hoping that Kittmaster had found a solution.
 Thank You!
(3,424 Views)
You can not change anything in the master database.  If you copy the part to your user or corp database, you can then modify it as needed.  Other than that, just send a report to NI for fixing.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(3,415 Views)
