04-09-2008 09:27 AM
04-09-2008 05:59 PM
I caqn possibly answer one of your questions at this time. The 3 yellow boxes are as follows (I believe since it was hard to make out on the schematic) Box P2=Power Switch Box P1a and P1b appears to be the main power sources. I am guessing at the last 2 yellow boxes based upon the circuit layout. They could also be connectors to the external power sources.
04-10-2008 07:24 AM
04-10-2008 09:15 PM
There are 2 phone plugs in the Master Database under BASIC>CONNECTORS that you can examine and see if they meet your requirement. They are labeled PhonePlug and PhonePlug2. It looks to me that PhonePlug2 is more suited to your application, but you will have to make that determination.
I hope this helps.
