Multisim and Ultiboard
Looking for a photoresistor component in Multisim
I can't find a photoresistor component in Multisim. Does anyone know any database for photoresistor components? Thanks in advance!
(7,915 Views)
Accepted by annebec02
Hello  annebec02,
NI Multisim doesn't simulate light. This is the reason that there are no Light Dependent Resistors (LDR) in Multisim. Instead of a Photoresistor, you can use a Voltage Controlled Resistor.
Or if you want to draw a Photoresistor for your scheme, you can use Component Wizard to do it. The link below might help you.
Creating a Custom Component in NI Multisim - National Instruments
Best Regards.
(7,877 Views)
Фотодиоды и фоторезисторы в программе всё равно управляются напряжением, так что такая замена весьма эффективна и универсальна, а "ухудшить" свойства под реальный компонент всегда можно
(7,864 Views)
