Multisim and Ultiboard
More than 8 Input
I wonder if there is any way to have more than 8 inputs  on Digout (e.g, entering two 8bit numbers for adding ) in multisim.
Message 1 of 8
(9,497 Views)
Hi Hannaneh,
I'm afraid I don't completely understand your issue, if you could give me steps to recreate your problem, and maybe some images to illustrate it, this would be helpful in allowing me to troubleshoot further.
Kind regards,
Matt H
National Instruments UK
Message 2 of 8
(9,453 Views)
Hi, I am sorry that I wasn't clear enough. I need to add/subtract 2x8 bit numbers. So i need 16 inputs(8 for each number). I know multisim supports for 8 inputs. Is there anyway (except using switch/direct connection to Vcc and Ground) to extend it to 16 inputs to enter these two numbers?
Many thanks
Message 3 of 8
(9,450 Views)
Hi Hannaneh
I'm not entirely sure what you mean. If you mean you want to modify an exisiting IC, then you cannot do this. However you can create your own if you understand the logic, using the existing ICs to acheive this. For example you can acheive the adding of 8 bit numbers like this
I have attached the file with this circuit design for your examination.
I hope this helps!
Kind regards,
Matt H
Message 4 of 8
(9,440 Views)
Thank you so much for taking your time. It helped a lot 🙂
Message 5 of 8
(9,437 Views)
How would I turn this into an adder/subtractor circuit?
Message 6 of 8
(6,325 Views)
i want 8 bit parallel adder by nand gate on NI Multisim
Message 7 of 8
(5,207 Views)
Hi, I was wondering if you could please explain a way to do a difference between 2 numbers of two digits using a substractor please
Message 8 of 8
(5,160 Views)
