Guys, Please help I need Immidiate help with this problem!!
I'm learning now how to program PIC16F84, And found already a book to teach me CCS C,
I want to apply those projects on multisim, so the only way is to use the hex file with multisim, Because Multisim C language is very different than the CCS C Language
In Multisim, After I select the hex file I programmed, If the MCLR pin was connected to ground the simulation starts without results for of course, but If I connected MCLR pin to VDD, MULTISIM COMPLETELY FREEZES, And never work until I shut it down through windows, and so lose everything and nothing works
Please tell me if there is any modification should be made on PIC C project to make it compatible with multisim, Or if there is another compiler which is already tested on multisim using CCS C language
