Multisim and Ultiboard
New to multisim, question on this project
I started taking digital 1 class and have this project due next week, I put it together just like the lab book has it shown and I'm not getting the 7 segment display to display anything.  LEDs aren't turning on either.  If someone can help me out with this would be greatly appreciated.
(3,950 Views)
two of your power supplies are in backwards, and there is something wrong with the driver chip.  If I ground the output the segment lights up, if I do a lamp test, nothing works....probably problem with ic model......that is 5 minutes of anaylsis
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(3,936 Views)
Thanks for your help, I realized the backwards power supplies, put everything like this, still nothing displays on the 7 segment display.
(3,933 Views)
You should be more careful with the schematic entry.  For one thing you're applying -5VDC instead of +5VDC.  Check the polarity of your batteries.  It took some playing around with, but I got it working by using DGND (node 'GND') instead of AGND (node 0).  There is a difference in SPICE!
Also, I'm not sure if it's intentional, but your LEDs are dropping a constant 1.6V and only 3.4 V is getting to the input lines of the 74LS47N.  Seems to work regardless, though.
Let me know what I get for a grade.
-J
(3,932 Views)
Kittmaster beat me to it 🙂
Swap out your 'GROUND' symbols with 'DGND'
(3,931 Views)
Thank you so much for all your help.  Applied the DGND instead and works like a charm.  This is my first time using multisim so I'm still learning, it's a great program just takes time getting used to.
(3,928 Views)
