Multisim and Ultiboard
Oscilloscopes component test
hi .does any body know how to do a component test for example diode or transistor on multisim.where in real oscilloscope you connect the device to earth and component test inputs and you press component test button.
(4,480 Views)
Accepted by kulu
Hi Kulu,
I think your looking for the IV Analyzer instrument, instead of the oscilloscope. This will give you IV curves of diodes and transistors.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(4,464 Views)
ththank you man that was aquick solution.
(4,450 Views)
