Multisim and Ultiboard
Problem with Multisim: Async signal not support on 74ALS74AN?
A simple schematic to test 74ALS74AN.
Pin Q# is connect to pin D, and pin CLR# is control by a switch.
But the Logic of 7474 is wrong:
when J1 is on, CLR# is Lo, 7474 must be output Q=0,  but why Multisim report it like a Divider????
Similarly, when J1 is off, CLR# is high, 7474 must be output Q=D#(like a divider), why Multisim report output D=1.
Is it a bug with Mutlisim?
(5,518 Views)
Accepted by Jumbo.Lee
Jumblo.Lee,
The asynchronous Reset (Clear) and Preset pins are active LOW in this component. Your Preset is left floating and is actually being interpreted as a LOW. So when J1 is closed, both Reset and Preset are active, a hazardous condition you want to avoid in Latch and Flip-Flip circuits. It turns that this component ignores these asynchronous pins under such a condition. Thus you see the normal clock divider output.
To fix the issue, just tie the Preset pin to a HIGH.
Message Edited by MaxNI on 09-16-2009 09:21 AM
Message Edited by MaxNI on 09-16-2009 09:26 AM
Max
(5,507 Views)
I think 74 series IC's input pin is equivalent to the high when floating...
When I link Pin PR# to VCC, it's ok!
Thank you very much!
Smiley Very Happy
(5,493 Views)
