Multisim and Ultiboard
Resistor temperature coefficient setting
If I have a Resistor for 100Ω 1% ± 20ppm,and need to simulate. How to set the parameters of the Resistor?
(6,813 Views)
Double-click the resistor to open its properties, select the Value tab. Here you can configure tolerance, temperature coefficient, etc.
Fernando D.
(6,733 Views)
Hi, thank you for reply.
the normal resistor temperature coefficient is like 20ppm. How to select the value, just select TC2 and type number 20 into TC2?
(6,708 Views)
Accepted by kimi_
TC1 = (Coefficient) (ppm/°C)
Since ppm means parts per million, then we have the following equation:
TC1 = (Coefficient) (10-6/°C)
For a temperature coefficient of 20 ppm, TC1 = 0.00002.
Fernando D.
(6,688 Views)
Thank you so much. This is very helpful.
(6,673 Views)
