Multisim and Ultiboard
Starting Multisim
I seem to have downloaded Multisim Component evaluator, for Analog Devices, v. 11.0.2 successfully, and have un-zipped the 337 files.  Clicking on the program icon returns me to the User Account Control window, which leads back to the un-zip process.  How do I escape this loop?
(4,314 Views)
Accepted by rgaze
Hi Rgaze,
The file you downloaded from the website is a self-extracting zip file and when you double click on it, first, the installation files are extracted to your local harddrive: C:\National Instruments Download.  Once the files have been extracted, you should get a screen with the option to begin the installation.  If you have already gone through the installation already, click the Windows Start button>>All Programs>>National Instruments>>Multisim Component Evaluator>>Analog Devices Edition>>Multisim Component Evaluator 11.0 to launch the software.
Our installation doesn't add a shortcut icon on your desktop thus if you double click the file that you downloaded again, you will repeat the file extracting and installation process.
Tien P.
(4,300 Views)
Thanks, Tien
RG
(4,294 Views)
I have downloaded Multisim three times, and have now exceeded my internet download quota. In every attempt it returns Bad Format. Is the Multisim software available on CD, if so can I please have a copy. Thank You
(4,143 Views)
I have seen Multisim, and it contains a fundamental error, namely it allows a dual op amp to have its voltage rails attached with parts different for Channel A and Channel B. A dual op amp does not have seperate connections V+ V-for each channel, as they are inherently tied together. I am looking forward any way to receiving a CD.
(4,141 Views)
Please contact our technical representatives at: 1-800-263-5552. They will be able to send you an evaluation CD.
Fernando D.
(4,099 Views)
Thanks !
Regards
(4,090 Views)
