10-30-2011 02:30 PM
I seem to have downloaded Multisim Component evaluator, for Analog Devices, v. 11.0.2 successfully, and have un-zipped the 337 files. Clicking on the program icon returns me to the User Account Control window, which leads back to the un-zip process. How do I escape this loop?
Solved! Go to Solution.
10-31-2011 09:25 AM
Hi Rgaze,
The file you downloaded from the website is a self-extracting zip file and when you double click on it, first, the installation files are extracted to your local harddrive: C:\National Instruments Download. Once the files have been extracted, you should get a screen with the option to begin the installation. If you have already gone through the installation already, click the Windows Start button>>All Programs>>National Instruments>>Multisim Component Evaluator>>Analog Devices Edition>>Multisim Component Evaluator 11.0 to launch the software.
Our installation doesn't add a shortcut icon on your desktop thus if you double click the file that you downloaded again, you will repeat the file extracting and installation process.
10-31-2011 09:47 AM
Thanks, Tien
RG
12-10-2011 11:21 PM
I have downloaded Multisim three times, and have now exceeded my internet download quota. In every attempt it returns Bad Format. Is the Multisim software available on CD, if so can I please have a copy. Thank You
12-10-2011 11:41 PM
I have seen Multisim, and it contains a fundamental error, namely it allows a dual op amp to have its voltage rails attached with parts different for Channel A and Channel B. A dual op amp does not have seperate connections V+ V-for each channel, as they are inherently tied together. I am looking forward any way to receiving a CD.
12-14-2011 09:24 AM
Please contact our technical representatives at: 1-800-263-5552. They will be able to send you an evaluation CD.
12-14-2011 01:58 PM
Thanks !
Regards
