12-04-2007 06:50 PM
12-05-2007 07:37 PM
I am unclear on why you needed to update because 343 is the latest version and there has been no updates since unless you were updating to 343.
Anyway, The only solution I can come up with at the moment is to try and re-install it.
Can you tell me if your version was on a disk or did you download it from the web. If it came on a disk, then let me know so I can give you a possible solution to try. If you downloaded your version from the web then my option won't work (at least I don't know if it would work).
12-06-2007 09:25 AM
Hi Dejan,
1. You can fix the toolbar problem by deleting your current config file and this will reset your toolbars back to default. Close Ultiboard down and navigate to the following path:
C:\Users\Your login\App Data\Roaming\National Instruments\Circuit Design Suite\10.0\config delete the .ewcfg file in this folder.
2. The second problem is a little harder to fix but here is a suggestion that may help. Select Options>>Global Preferences>>PCB Design and uncheck the “show copper area”.
12-06-2007 11:13 AM
12-07-2007 07:06 PM
I do not have Vista so I cannot say if what your seeing is related to it, but I would have to say that a memeory management problem would cause any software to run slowly or erratically. I would venture a guess that Ultiboard on large projects would be quite hungry for memory especially when it tries to autoroute.
I have had instances of stutterring from it. I wouldn't call it freezing as much as an extremely long pauses after it does a task like autorouting and then goes to update the main screen.
You could try disabling all background software including virus protection software, etc. There is usally a lot of "junk" that windows loads on start-up (at least on my XP anyway). If you get rid of the ones that aren't critical to system operation through the task manager it may free up more resources for Ultiboard.
I don't know if any of this helps, but this is all I know since I don't have Vista on my system (I use XP).
