Multisim and Ultiboard
Ultiboard 14.0 : Drill file is corrupted
There are errors in the drill file. See attachment. There something wrong with the floating point (NO floating points in the drill file)
Lieven
Message 1 of 13
(7,452 Views)
What do you mean by corrupted? How have it become corrupted, is it a drill file generated through ultiboard without modifications? What format are you using? Have you followed the tutorial on the link below?
Exporting Gerber Files from NI Ultiboard
http://www.ni.com/tutorial/6952/en/
/Anton
Message 2 of 13
(7,389 Views)
Hi Anton,
Gerber files are OK it's only the drill file is not OK.
The file looks like:
M48
METRIC,TZ
VER,1
FMAT,2
DETECT,ON
ATC,ON
T1C3.0000
T1
X50000Y350000
X150000
M30
and it must be:
M48
METRIC,TZ
VER,1
FMAT,2
DETECT,ON
ATC,ON
T1C3.0000
T1
X5.0000Y35.0000
X15.0000
M30
NC drill and gerber properties are set to METRIC. Coordinate format for geber and drill are set to 3/4
Lieven
Message 3 of 13
(7,381 Views)
Hi Lieven,
I tried doing a quick test, and I get the same behaviour when trying to generate a drill file. Are you sure that the file is corrupt, i.e. are you sure that there should be decimal points in it? What format are you using, the standard format should be the excellon format and in this there should be no decimal points.
https://en.wikipedia.org/wiki/Excellon_format
I tried opening the file with the online gerber viewer and it seem to understand the coordinates, how do you view the drill file?
/Anton
Message 4 of 13
(7,335 Views)
Hi Anton,
Are you use my attachments Anton ? I guess that you make, or create a new file. So i download ultiboard 13 (Demo). and create the same drawing in ultiboard 13. After generating the gerber and drill files all
the problems with the drill file are disappeared. Thats not normal. So what can i say. Maby the file is not corrupted(14) but the generated data is wrong.
Kind regards,
Lieven
Message 5 of 13
(7,319 Views)
Hi Lieven,
I tested both with your attached file and by making a new one and I saw the same result, that is no decimal points in the drill file. So are you saying that you get the decimal points using ultiboard 13?
/Anton
Message 6 of 13
(7,317 Views)
Hi Anton,
I generate the files now in Ultiboard 13 (Demo) yes. And yes there are decimal points in the drill file. See new attachment below.
Lieven
Message 7 of 13
(7,309 Views)
Hi Lieven,
I have not been able to get a definite answer to wether the missing decimal points are the expected behaviour or not. Since they are in version 13 of Ultiboard I have submitted a corrective action report and I'll let you know what reply I get.
/Anton
Message 8 of 13
(7,278 Views)
Accepted by Lieven_1
Thank you Anton. I'm still waiting for a solution.
Lieven
Message 9 of 13
(7,271 Views)
Do you have access to Ultiboard 13 and can you use this in the meanwhile? An other solution would be to either programmatically or manually parse the file and insert the decimal points.
After the problem has been verified by R&D it will still take some time to fix, verify and releas of an eventual patch, so I would not wait for it.
/Anton
Message 10 of 13
(7,268 Views)
