08-08-2011 09:48 AM
Even when I turn off viewing of all layers except the current, I still see the outline of all the components on the PCB. They are still there when I switch the current layer to some other layer as well and turn off viewing of the previous current layer as well.
I don't remember ever turning on some option to view component outlines and can't see any options for during such a thing as I look at all the different options.
I am using Ultiboard 11.0.2 with Windows 7
Attached is a screen shot of the problem.
Solved! Go to Solution.
08-08-2011 10:03 AM
08-08-2011 10:29 AM
No, I started it from scratch in Multisim/Ultiboard.
The environmental changes recently were I upgraded to Multisim/Ultiboard 11.0.2 and from Vista to Windows 7
I think this might have been the first time I opened this project since the upgrade.
08-08-2011 10:48 AM
Hi Rick,
Is it possible for you to post your design file. I would like to take a look at what is causing this issue.
09-27-2011 02:07 PM
The attached file shows the stray board outlines on my workstation
(Windows 7, Ultiboard 11.0.2)
Rick
09-28-2011 08:14 AM
Hi Rick,
The outline on the parts is just showing that they are currently locked. If you right click the outline and select unlock, the outline will go away.
09-28-2011 09:38 AM
Kudo's for you, Dummy hat for me ![]()
