Multisim and Ultiboard
Ultiboard copper pattern
Hi all,
I'm using Ultiboard 12.0 and I need to create a pattern filled copper area.
I've already found some docs on internet stating that changing the "fill style" of a copper object was enough. While trying, I see this option but when I change the pattern style this makes no change, the area is still drawn as a solid region. It may only be a graphical bug but when I try to print the copper layer it prints as a solid one.
Any help would be greatly appreciated.
Kind regards,
Aya
(5,191 Views)
Accepted by Ayashi
Aya,
Try this:
right click on the copper area in which you want a hatch.
then select the hatch type you want (tab copper area)
then go to the tab 'general' and change the width value...
If that is too small or too large, the hatch appears like a full copper area
succes!
(5,173 Views)
