 dadib
			dadib
			01-04-2008 08:50 AM
01-04-2008 09:06 AM
Hello again,
Can I exchange data in multisim time simulation with LabView (I have read that LabView can "send out" signals through the paralel or serial port) ? I have read some topic about how to save multisim simulation informatios and then import into LabView. This can be done automaticaly ?
Thx, Daniel
01-04-2008 09:29 AM
Basically, you can use any port or I/O that LabVIEW offers from inside Multisim, even when a simulation is running.
The problem however is the different time base of the "real world" and the SPICE Simulator". Take a signal with a frequency of 1kHz for example. The SPICE engine might need more or less than 1ms to calculate/simulate one period of the signal, depending on the complexity of your circuit or CPU power of your PC. The speaker instruments that ships with Multisim, greys out as soon as the simulation starts,to avoid mismatch in time.
So if you take the different time bases into account you can send data from Multisim via a LabVIEW based instrument to the serial or parallel port.
The following link shows how to create a LabVIEW based instruments:
http://zone.ni.com/devzone/cda/tut/p/id/563501-04-2008 03:12 PM
 Cjuried
			Cjuried
			05-08-2016 02:15 PM
I am using MultiSim 14 and also have Labview on my machine. When using the speaker instrument, I am able to record and playback my simulation. However, the issue I am running into has to do with playback time. Not matter how many seconds I set the instrument to record, it only plays back a short blip of the recorded signal. Any thoughts? Thank you.
Best,
Chris
