Multisim and Ultiboard
convergence error
i make a simple circuit with a relay, i have a scr to latch and energize the relay.
the circuit works no problem, but when i put a diode across the coil like we always do with relay coils,
it gives convergence error.
i have version 11 student edition, and cant change the ERC rules.
what can i do, it is very frustrating that a basic circuit wont work.
(4,232 Views)
Hello fusseltier,
can you please post the schematic so i can test it.
best regards
Alexander
(4,205 Views)
here are the same circuit, with and without the diode.
i sent this in to national instruments and they said they dont have an answer for this problem.
only that since i have the student version i cant turn off the ERC rules.
(4,201 Views)
Accepted by fusseltier
Hello fusseltier,
if you are using probes instead of the instrument no error happend.
Please let me know if this helps.
best regards
Alexander
(4,198 Views)
wow, i didnt think to try to remove the meters. in my old electronics workbench i could have all the meters and test equipment i wanted in a circuit and it worked... unfortunately i cant get that program to work anymore, and have to use the student version of multisim and its limitiations.
thanks, i'll try to not use meters, but i hope when i really need one it works.
(4,187 Views)
