Multisim and Ultiboard
erroe calculates
Sorry-did the double messages
Message 1 of 8
(6,007 Views)
Hello.
There was a small problem. Multisim software versions (10 and 13) calculates the value of the polynomial at a particular point in a different way. In what could be the problem..???
At this point should be -3, 553mV.
Message 2 of 8
(6,006 Views)
 Hello.
Multisim Version 13 (13.0.995) makes a mistake in the construction of a negative number to an odd degree. Sign of the resulting number is still positive for the template record exponentiation. If a negative number multiplied three times consecutively, the result will be correct.
Or this problem is known and has already been solved .. ???
Message 3 of 8
(5,966 Views)
Hi Vlad,
It looks like there is a problem with the ABM calculation; I will ask the developer to look into this problem.
Tien P.
Message 4 of 8
(5,914 Views)
Thanks Tien!
The same problem and in Multisim version 12.
Message 5 of 8
(5,909 Views)
Hi Vlad,
Just tested this in V12 and it's also a problem.
Tien P.
Message 6 of 8
(5,882 Views)
Thanks Tien.
When the developers fix this problem .. ??? ... how soon will the patch .. ???
The issue is not related to this topic ...
How do I create Multisima SPICE model and connect it to the animation (eg heating of metal) ... ?? SPICE model, I do, but how to make animation .. ?? Maybe there is a guide .... prompt.
Message 7 of 8
(5,873 Views)
Hi Vlad,
I am not sure when our developers will fix this problem, there are factors like what resources are available, the defect severity and are part of the decision when things get fixed.
Animated components have custom code to make it behave a certain way and it's hard coded. A user does not have the ability to add animated parts in Multisim
Tien P.
Message 8 of 8
(5,862 Views)
