Multisim and Ultiboard
[multisim] How to attach a schematic subcircuit to a symbol?
Hi guys
I have a schematic circuit that I want to use as a subcircuit to a symbol. I mean instead of attaching a SPICE model to define a symbol, I want to have a subcircuit. So, I need to know how to define pins on the schematic and map it to a custom symbol that I want to make.
In Cadence, it is very easy. I can have a symbol, and can attach SPICE or veriloga models, or a schematic. But I don't know how to this is Multisim.
Any help is appreciated! 🙂
Regards
Vahid
(6,354 Views)
Accepted by VahidK
Hi there,
In Multisim, all you need to do is to select the circuit (ctrl +A) and right click, there is an item called "Replace by hierarchical block  Ctrl+Shift+H". Then name the block and place it.
Hope this helps!
Chen_T
(6,345 Views)
Thanks a lot Chen
That surely helps, but the problem is that now, I just have a box with no pins. I want to be able to assign pins to that hierarchical box, edit it's symbol, and everything else that you do with a new component symbol (in order to use it as a component in my circuit designs). Can you help me with this?
Bests
Vahid
(6,328 Views)
And I think I figured out how to do the rest. For pins i added Hierarchical connectors. And after I got the box with the pins I could right click and edit symbol.
Thanks again
(6,322 Views)
