Multisim and Ultiboard
sma footprint
I just started using Multisim/Ultiboard, and I'm having problems creating a footprint for an edge-mounted SMA connector similar to this:  http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=J502-ND
I can easily create 3 pads on the top layer, but I would also like to make 2 pads on the bottom layer.  I have tried manually adding copper areas to the bottom layer directly below the copper areas on the top layer, but I get an error saying something is already there.
Does anyone have experience with doing this, or better yet is there a part I can download to use these connectors?
Thanks!
(5,509 Views)
Accepted by BenNRL
In the footprint editor mode place the pads on the work area and then right click on them>>Orientation>>Swap layer or (Alt+S)
Tien P.
(5,480 Views)
