Multisim and Ultiboard
sma footprint
I just started using Multisim/Ultiboard, and I'm having problems creating a footprint for an edge-mounted SMA connector similar to this:  http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=J502-ND
I can easily create 3 pads on the top layer, but I would also like to make 2 pads on the bottom layer.  I have tried manually adding copper areas to the bottom layer directly below the copper areas on the top layer, but I get an error saying something is already there.
Does anyone have experience with doing this, or better yet is there a part I can download to use these connectors?
Thanks!
(5,550 Views)
Accepted by topic author BenNRL
In the footprint editor mode place the pads on the work area and then right click on them>>Orientation>>Swap layer or (Alt+S)
Tien P.
(5,521 Views)
