Multisim and Ultiboard
tvsop footprints
Looking for footprints for TVSOP parts (aka MO-194 or MO-153) (e.g. TVSOP14 == SOP40P640X127-14N, TVSOP16 ==  ...16N etc).
Has anyone done those - parts in this size are now very common e.g. SN74AHC14DGV.
Dave
(5,202 Views)
Hi Dave,
I haven't found the footprint you're after however you can follow the product seggestion link below and suggest it so it may be included in future versions.
http://digital.ni.com/applications/psc.nsf/default?OpenForm
Also, you can actually create your own custom footprints. Follow the link below to see a step by step guide.
http://zone.ni.com/devzone/cda/tut/p/id/3173
I hope this has been helpful.
Kind regards
Rico P
Smiley Very Happy
(5,168 Views)
Hi Dave,
I would take a look at the PCB Matrix LP Viewer/Calculator if you're not already familiar with it.  It's a free tool that provides IPC-compliant dimensions for land patterns.  I was browsing through their database, and noticed that they already have many standard TVSOP packages in the surface mount nominal library, but it is simple enough to use the calculator if you do not find the exact packages you need.  They also have an export tool that will automatically create the land pattern for you in Ultiboard, which is especially useful if you find that you are always creating them manually.  There's a link to a DevZone article on how to do this here:  Accelerating the Creation of Custom Land Patterns.  Otherwise you could use the Part Wizard to create them manually.
Natasha Baker
R&D Engineer
Join the NI Circuit Design Community
Follow Multisim on Twitter!
(5,007 Views)
Accepted by topic author david_c_partridge
david_c_partri… ,
Just to clarify the LP Wizard calculator is free, however I do believe the export tool is not.
Also here are the TVSOP parts you've requested - these are Ultiboard shapes only but can be used to easily create TVSOP variations of components.   I've placed them in the community page.
http://decibel.ni.com/content/docs/DOC-7166
Patrick Noonan
Business Development Manager
National Instruments - Electronics Workbench Group
50 Market St 1-A
South Portland, ME 04106
Phone: 207 892-9130
Email: patrick.noonan@ni.com
(4,979 Views)
