02-24-2012 05:45 AM
i am using MQ-5 gas sensor to detect LPG and the output voltage is range 0-5v. this range is divided into sampling volts each = 0.00488
so the total samples=1023, 1 sample =5/1023 = 0.00488
i want to convert the amount of output voltage detected by gas sensor to PPM(part per million) . How?
02-29-2012 08:30 AM
I am not sure if this is a Multisim issue. Are you trying to build a circuit for this gas sensor? If so, can you post the circuit so we can try to see what is going on.
09-27-2012 04:53 AM
sir,
how to convert voltage obtained from the CO sensor to the concentration of CO?
we need formula to calculate manually.................!
