NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
Problem with imageViewer
Hello Every~
I want to use ContexMenuStrip in ImageViewer .But it cant Work. So I used imageViewer_MouseUp,It cant Work also.
Only imageViewer_ImageMouseUp can Work,But It can return the point that I need.
OnlyOne can Help me~
ThankS all.
 private void imageViewer_MouseUp(object sender, MouseEventArgs e)
     //Do something
This event cant work~~~~
0 積分
1 條訊息(共 11 條)
7,120 檢視
Which version of  Vision Deveolpment Module do you have?
Which OS?
Which version of c#?
0 積分
2 條訊息(共 11 條)
7,112 檢視
I used Vision Deveolpment Module2010
 Which OS?
Windows Xp Sp3
VS2008  C#
0 積分
3 條訊息(共 11 條)
7,110 檢視
Hi McLovin,
As you said, event of imageViewer_ImageMouseUp can work, but can't(?) return the point you need.
Can you tell me what the "point" mean? (Mouse position?)
0 積分
4 條訊息(共 11 條)
7,098 檢視
Thanks For your Help!
I mean I need to use The( imageViewer_MouseUp)Event not  imageViewer_ImageMouseUp Event.
I know imageViewer_ImageMouseUp can work,but the imageViewer_MouseUp can`t.
I used vs 2008 c#  use vision tool ImageViewer.
0 積分
5 條訊息(共 11 條)
7,093 檢視
Vision Development Module 2010
or
Vision Development Module 2010 sp1 ???
0 積分
6 條訊息(共 11 條)
7,089 檢視
0 積分
7 條訊息(共 11 條)
7,081 檢視
try to get sp1.
it may solve the bug.
0 積分
8 條訊息(共 11 條)
7,078 檢視
what`s the differents between the two softe?
0 積分
9 條訊息(共 11 條)
7,070 檢視
Hello:
Vision Development Module 2010 sp1 Still have the problem.
0 積分
10 條訊息(共 11 條)
7,021 檢視
