NI產品與技術 討論區
取消
顯示結果
搜尋替代
您的意思是:
daq usb-6229與matlab連節
已解決!
前往解決方案
我使用daq usb-6229與matlab連節時好像有點問題??
首先在matlab command window下
daqwinsoundinfo = daqhwinfo('nidaq')
daqwinsoundinfo =
           AdaptorDllName: 'C:\Program Files\MATLAB R2009\toolbox\daq\daq\private\mwnidaqmx.dll'
        AdaptorDllVersion: '2.14 (R2009a)'
              AdaptorName: 'nidaq'
               BoardNames: {'USB-6229'  'PCI-6221'}
        InstalledBoardIds: {'Dev2'  'Dev3'}
    ObjectConstructorName: {2x3 cell}
這是有抓取到'USB-6229'  和'PCI-6221'
可是我再輸入
ai = analoginput('nidaq','Dev2');
ai
??? Attempt to execute SCRIPT analoginput.analoginput as a function:
C:\Program Files\MATLAB R2009\toolbox\daq\daq\@analoginput\analoginput.m
卻出現以上的結果??
當輸入analogoutput時:
ao = analogoutput('nidaq','Dev2');
ao
Display Summary of Analog Output (AO) Object Using 'USB-6229'.
       Output Parameters:  1000 samples per second on each channel.
      Trigger Parameters:  1 'Immediate' trigger on START.
           Engine status:  Waiting for START.
                           0 total sec. of data currently queued for START.
                           0 samples currently queued by PUTDATA.
                           0 samples sent to output device since START.
AO object contains no channels.
 那為什麼在input的時候會這樣??
daqmx  8.5.0f3
0 積分
1 條訊息(共 3 條)
7,465 檢視
解決方案
接受者 agersir
建議找 matlab 台灣代理商
或使用 LabVIEW
http://forums.ni.com/ni/board/message?board.id=5170&thread.id=3908
2 條訊息(共 3 條)
7,445 檢視
如果有解決到您的問題麻煩您勾選已接受解答,並且給我一個獎勵!謝謝~~~
3 條訊息(共 3 條)
7,417 檢視
