The latest version of Circuit Design Suite just released last week (11.0.1), and so I can finally write about something I added to the product some time ago.
Finding items in Ultiboard (Edit > Find...) shows the list of found items in the spreadsheet. Previously, you could double click the item, and it would take you to the location of the item, or the location of the item when it was found. This has been improved in a couple of ways for the latest version.
You can use these new commands to select the found attribute (or select multiple attributes), and then edit multiple attributes at once, even if they are not visible on the board. To give it a try, I'll show explain how you can the visibility of all DIP8 attributes to visible without going component-by-component.
1. Click File > Open Samples, then select and open RoundRouted.ewprj
2. Find and select the items to modify
For each item, right click the item and choose Add to selection
3. Change the visibility of the attributes
4. Now when double click the items, you will see the visibility of each.
