When you are simulating a design, the Run simulation button (the play button), is disabled in other schematics since Multisim focuses on simulating one design at a time. I often have multiple designs open, and sometimes I select another design, forgetting to stop the running simulation. I then cannot start a simulation in this new design because I forget I am already simulating in another design. The question is, how do I know which schematic to select to stop simulation?
With Multisim 11.0.1, just look in the Design Toolbox on the Hierarchy tab. You'll now see a simulating icon flashing identifying the design that has a running simulation. In the case below, the simulating design is AdjFreqAmp.
