This widget could not be displayed.
NI ELVIS
NI ELVIS Oscilloscope Error 200077
While running NI ELVISmx Oscilloscope for ELVIS II at CH0 or CH1 I'm getting error  -200077.
The error states:
Error -200077 occurred at Property Node DAQmx Timing (arg 1) in ELVISmx_subScopeAcquire2.vi->ELVISmx_subScopeAcquireData.vi->Scope.vi
Possible reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Device: Elvis
Property: SampQuant.SampPerChan
Value: 1
Maximum Value: 16384
Minimum Value: 2
Task Name: _unnamedTask<1>
Any suggestion?
Message 1 of 8
(8,174 Views)
Change the property value "2".
Certified LabVIEW Developer
GCentral
Message 2 of 8
(8,163 Views)
Many thanks sir, but is there a way to change the value at ELVISmx? or at MAX? I am a newbie
Message 3 of 8
(8,134 Views)
The property would correspond to "Record Length". You can change the value on Configuration Tab.
http://zone.ni.com/reference/en-XX/help/372500F-01/372500f/elvisexpress_oscilloscope/
GCentral
Message 4 of 8
(8,115 Views)
Hi Erwin,
This is a known bug for the 2019 version of the ELVISmx software and has been targeted for a fix in the next patch.
For the time being, I recommend upgrading to the 2018 version of the software.
Cheers!
Jacob
Jacob Hopkins | CLD
Message 5 of 8
(8,007 Views)
I get the same error using the elvismx 2018 version. It's possible to use the AI but not the channels.
Message 6 of 8
(7,550 Views)
请问专家,如何解决?
Message 7 of 8
(5,550 Views)
请问如何解决的?我卸载Elvismx重装后,还是这样,怎么办?
Message 8 of 8
(5,548 Views)
