NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
Create Property Node
已解决!
转到解答
我在一个VI中,同一个控件要用许多Property Node,Reference,Local Variable,一个一个Create好麻烦,又慢,可是又不能Ctrl+C—Ctrl+V,有没有比较省事儿的方法可以快一点创建出Property Node(或Reference和Local Variable)?
谢谢!
帖子被ThomasYoung在 01-26-2010 01:53 AM
时编辑过了
Thomas | Xi'an China
LabVIEW 7.1 | LabVIEW 2018
DAQmx | CompactRIO | myRIO
微信公众号: 钟博士LabVIEW工作室
1 条消息(共 12 条)
8,839 次查看
解答
接受人 ThomasYoung
Assuming that you have created a property node (of the control)...
  1. Highlight the property node with a mouse click i.e. the property node should be highlighted with dashed-line (see image 1)
  2. Now, depress [Ctrl] key and holds it.
  3. With mouse, click on the property node and drag.
  4. You have just created a copy of the property node, reference or even local variables 🙂
highlighted property node.PNGimage 1
Message Edited by ian fung on 01-26-2010 04:02 PM
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
2 条消息(共 12 条)
8,834 次查看
哇,哇哇,太好了,太谢谢你了!!
0 项奖励
3 条消息(共 12 条)
8,825 次查看
There are more you can do with [Ctrl]+[mouse click & drag]
i.e. If you realize that you need more room within a Case/ Loop or anywhere in the Block Diagram, you may, depress the [CTRL] key, carefully choose the "expand from" location, mouse-click & drag.
This will create more room in a congested block diagram 😉
room before.PNG before [ctrl]+[click & drag]
room after.PNG  after [ctrl]+[click & drag]
Ian F
依恩与LabVIEW
4 条消息(共 12 条)
8,823 次查看
极度高兴的表情LabView中是不是有许多快捷键?可不可以讲讲呢?可以加快编程速度。
0 项奖励
5 条消息(共 12 条)
8,816 次查看
的确是有很多... 其实一时间也说不上来. 倒是您提问了而我也知道并经常使用这些快捷键才能"对答如流";)
也许是因为自LabVIEW5.1开始使用LabVIEW, 有许多所谓的Advanced Tools/ Express VIs, 我都不常用. 尤其是 Automatic Tool Selection, Place Front Panel Terminals As Icons, Automatic Wire Routing etc. 这些功能, 对我而言, 只会把图框弄得更乱!
I do not use "Automatic Tool Selection" but using "tab" to change to the tool that I want.
I do not use "Automatic Wire Routing" because it is horrible 😉 I am concern about neat "wiring" 😛
I do not "Place Front Panel Terminals As Icons" because it is block-diagram-space-consuming 🙂
And many many more...
也许, 有时间的话, 我能逐个写出来... 放到我的网站吧!
Ian F
依恩与LabVIEW
6 条消息(共 12 条)
8,812 次查看
其实, 上面两个[CTRL]+[Mouse CLICK & DRAG]的快捷键已经能让您编程愉快!
Ian F
依恩与LabVIEW
7 条消息(共 12 条)
8,810 次查看
极度高兴的表情期待...
若是哪天写好了,可否告知在下?
再次感谢!
0 项奖励
8 条消息(共 12 条)
8,809 次查看
当然! 当然! 😉
Ian F
依恩与LabVIEW
9 条消息(共 12 条)
8,801 次查看
你的网站的网址是什么?
0 项奖励
10 条消息(共 12 条)
8,772 次查看
