Hi all,
Recently, I came across a problem that creating a vertical dashed line over the graph. I searched the relative information in the discussion forum, but I can't find the solution. A lot of people are talking about creating the cursor, but my target is not a cursor.
My problem is... I would like to create a vertical dashed line to the graph, which waveform has already there. The x and y values of the line can be controlled by the controller box. Any help is appreciated!! Thank you in advanced.
Tinam
已解决! 转到解答。
Hello Tinam,
you could use the "XScale>>Marker Values"-Property to add a vertical line to your graph.
Hello My Ni:
Thank you for your response.
Do you mean use the property node of the graph?
But I can't find the "Maker value" you mentioned. Could you please give me more information? Thanks again.
Tinam
Hi MY,
Thank you very much! It is a kind of way to create a vertical line, but the line is not highlighted. Is there any way to make it highlighted?
Tinam
